New Build (inc Pics)
14 Oct 2009
UK
Hi guys,
After much deliberation i have decided to move to the blue side at least for now and possibly back to BullDozer if its better.
I dont yet have the main parts yet but here is what i have ordered.
* Intel Core i5-2300
* HIS AMD 5770 1GB
* OCZ Vertex 2e 120GB SSD
* 8GB DDR3 1333 RAM
* Asus P8H61-M mATX motherboard (new b3 revision)
* Lian-Li PC7Fwb (Thanks mrk)
+ What i currently have....
* Thermaltake TR2 550w
* WD Caviar Blue 500gb
* Seagate 640gb
* Benq G222HDL
I will update as i go along but for now here is a pic of my new case :)
Well its not much of a project as i am not modding it in anyway etc so i didnt think it would be worth posting there. Mods if you consider it a project then by all means move it.
and thanks :)
Ok,
Here is a box pic...
I am just installing the CPU,
When i push down on the lever/clasp it sounds like a crunching/scraping sound. Does that sound right?
Here is a pic..
It does make a sound when you push the CPU down so it should be normal.
If you're worried just remove to CPU and make sure no legs have fallen off :)
It does take a bit of force to get the CPU mounting arm down and locked - plus it may make a bit of noise (since it's metal scratching against metal). This is all normal.
Well it went in fine and so did the cooler...
Here is a pic of my 'workstation' today....
Can i still run Prime even though i am only using stock cooler?
Or what other test should i run to check its all fine before installing in the case.
All done :D
I will update when i have finished installing everything and set it all back up in my room.
I must say i was not going to get a SSD but WOW! It is truly incredible. Just installed everything i use in less than 5 min. 20min+ on normal hdd.
Incredible!
i like that case, and you got it for a bargain :(
was watching it on the MM.
It is really nice, a bit bigger than i thought but will be good for future expansion.
I don't think it's such a great idea to be building on a blanket. The surface of the desk would be much better.
Its a towel fyi :p and its too late now its all in and working perfectly!
All done :D
Incredible!
I thought it was a towel at first, then looking at it. It looked far to fluffy and soft to be a towel!
Where did you get them??? I need some of them... OcUK don't stock them do they :D
:eek:
That is a real old one kept for things like this :p
I think they were from TKMAXX who have some real good stuff if you look :)
I have now fully updated and will take some more pics later
I live in towel poverty :( Mines are more like 10 year old sand paper with squiggly lines on them!
Glad you like it.
P.S. There's no real need to stress test a CPU that's not overclocked.
Towells
And remember when stress testing the towel air cooling works much better than watercooling as they lose there drying capacity.
:D Sorry couldn't resist
Glad you like it.
Yeh loving it so far.
I know but i just wanted to check it.
:confused:
Here are some pics i took with my phone.
Done my best with the cabling so far, having non modular and 3 hard drives doesnt help :(
