understated watercooling lian li pc-a71f
1 Feb 2009
Wiltshire
realising my watercooling ambitions
I have been desperate to do this for a year, I'm finally getting round to doing it
This is my first watercooling attempt!
Its all going into a lian li pc-a71f
I have bought the following watercooling parts already:
swiftech 120mm qpk radiator
ek 250 multi option advanced
ek dfi northbridge block
2x swiftech mcp 655
2x ek d5 x-top
17x bitspower 1/2" barbs
2x bitspower 45 degree adapters
aquacomputer tubemeter usb
3x black 140mm fan grills
akasa apache 120mm fan
Koolance VID-AR697
Koolance 1/4" Thread Inline Flow Meter
Koolance Flow Meter Frequency Adapter for Koolance INS-FM17N Flow Meter
3x Noiseblocker BlackSilent PRO PK3
Reducing socket from G1/4" to G1/8"
Bitspower 1/4" Thread Temperature Sensor with 2 Pin Cable Black Sparkle
3x Phobya 140x140x7mm Shroud & Decoupler
Mayhems dye biocide
koolance 370 cpu block
Coolgate CG-420
deionised water
and my still to buy list (to be bought and installed after initial build if required):
3 meters of Masterkleer Hi-Flex 7/16" ID - 5/8" OD
2x noise blocker pk2 140mm fan
Koolance CTR-SPD10 12v pump controller
some mesh of some kind
12 countersunk, black, 6-32 x45 (ish) screws which dont seem to exist :(
sound proofing material for pumps
I'm ready to build when these parts arrive!!!!!
some countersunk, black, 6-32 screws which dont seem to exist :(
im looking at about 45mm maybe a little bit less could be acceptable. i guess that would be 1 3/4 inches?
done a search found a few but not in black yet
works out a M3.5 x 40/45mm .. there is a few types about.. can i ask what they are for
they are for holding the radiator and fans + shroud to the roof of my case, i have the phobya ones and they are about ok, just not countersunk :(
the prices of those security screws are insane btw.
i may have a rethink and see if i can do this another way, but i dont think i can :(
