- 1 Aug 2011
Okay, once im in that how will i know whats what like if the ram is working gahh so confused o.O! lool
..just don't know why it was acting ok up to this point then suddenly does that now?Oh the stick in the computer ATM works. If i take that out and put the other one i get the BEEPS so i guess it's 100% FAULTY.
Hmm, might buy some different RAM and just get a full refund on the stuff I got ATM just my luck..just don't know why it was acting ok up to this point then suddenly does that now?
Hmmm, do you suggest I just order new sticks as I've heard getting a new set of RAM/general products will take a while. And should this experience put me off purchasing the same RAM? or was I just unlucky
According to the manual you should populate dimm4 first which should be the slot furthest from the processor. The second stick should then presumably be in dimm2.
You were unlucky if you got faulty Corsair XMS3.
It can take a while to sort out an RMA depending how long they take to test it and if they replace it out of stock or have to wait for some from Corsair.
The option with the least downtime is to buy some more and return the faulty RAM but ask for a refund rather than replacement. If you've not had it long there shouldn't be a problem getting a refund.
If you're thinking of buying some new sticks perhaps consider if you'd benefit from 8GB.
Very good price on these at the moment:
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
could order today and get it by Tuesday and it'll be all sorted *fingers crossed*
They were in those slots.
Yeah, sounds like the best plan. But 8GB of RAM is that really that nessecary but I suppose it's future proof but then again I only; play runescape browse web/ record in game footage etc. Not too demanding but pretty cheap at same timecould order today and get it by Tuesday and it'll be all sorted *fingers crossed*
That's okay then. In your earlier post you said you were using the blue slots. From the available pictures this would have been slots 1 and 3.
Im using the blue slots WTF so they go in black slots o.O so confused!
