How to instert drivers onto Win7 64bit USB
25 Apr 2011
Crawley/Gatwick
Good Morning!
Burning question for today is, how do i insert drivers onto OS USB stick? So while os is being installed drivers will also be installed, if thats a possibility of course. I am not much of a programmer, in fact dont know anything in that area and was wondering if its posible and if anyone actually achieved that.
*EDIT*
Also i was wondering if its posible to integrate usb3.0 drivers into os boot so that they work
Thank you
Thank you for the reply, i didn't think it would be that complicated, thought its just the case of taking a folder with drivers and placing it somewhere amongs the os :) Cheers for help
use nLite and create your own custom windows install, means it will install your selected drivers/programs durring the initial windows install.
http://www.nliteos.com/index.html
or
http://www.rt7lite.com/
From what I remember its relatively noob-friendly too.
Nlite is for XP and Server 2003 only and will not work with Win7
Use RT7Lite or This one that I found last night and is very good (just finished testing my custom install in a VM) :)
