I want a 27", 120hz, LED, IPS screen.
8 Nov 2004
Do any exist and can I buy one for up to £600?
Or what is the best option for that cash if I cant get all of that spec.
Thanks
OK so I guess its down to gaming vs image quality.
Are the 120Hz screens worth it for gaming or is it only noticable for pro's?
I do like good picture quality with deep blacks so really wanted an LED screen. Or are modern TN panels good enough nowdays?
I currently have a Dell 2007 WFP.
Due to the edge-lit implementation of current PC monitor LED backlights the black level won't be any better than a standard CCFL backlit monitor, since the "full array" backlighting technology that gives some higher-end LED backlit LCD TVs their excellent black levels and true contrast ratios has not crossed over to PC monitors yet. (some more info here)
As for panel technology, TN and IPS are roughly equivalent in terms of black depth. However TN panels are more responsive, while IPS panels offer more accurate colour reproduction and much wider viewing angles. However, VA panels are quite a bit better than both of these technologies for black level and contrast ratio - but tend to be less responsive than even IPS (so you may see ghosting) and their viewing angles are better than TN, but not as good as IPS.
Then you are currently sitting on either a VA or S-IPS panel (I believe there was a panel lottery with that monitor), but bottom line it is a high quality non-TN panel with a CCFL backlight.
I would suggest upgrading to a new IPS (or possibly VA) monitor or you will see drop in image quality. I would suggest IPS, since they are more suited to gaming due to faster response times. The Hazro HZ27WC is pretty nice.
OK. I am looking at this Hazro HZ27WC or this Samsung S27A750D.
Want it in time for Battlefield 3.
Which should I go for?
