What is the best gfx card I can get for £175? :)
MSI GeForce GTX 560 Ti TWIN FROZR II 1GB NVIDIA Graphics Card
N560GTX-TI Twin Frozr II/OC - 1GB MSI GTX 560 Ti Twin Frozr II/OC, 40nm, 4200MHz GDDR5, GPU 880MHz, Shader 1760MHz, 384 Cores
Any good? I can't upload the link due to the rules. Its £184.27.
I can't decide between the HD 1GB 6950 or GTX560Ti 1GB. :S
Here are some comparisons for you:
HD 6950 1GB v GTX 560 Ti Anandetch
HD 6950 1GB v GTX 560 Ti Hardware Compare
Given your statement "I don't understand all this clock business" I'm assuming you don't know that much about the operation of PC's so I apologise in advance if I'm treating you as less knowledgable than you are.
In order to run either of these cards you need a PC with a free PCI-E x16 slot, a processor which won't bottleneck the graphics card and a decent power supply of around 500W with two 6 pin PCI-E power connectors.
If you can tick all those boxes then fine.
If you don't understand any of this, or need some clarification, then please post back.
That card is £179.99 in the today only section now ;-)
