well, you can pick them up for £4 on amazon. that doesnt shout quality to meSo mine are terrible and I should just get something else?
*edit*
after google reverse image search, this is what i found:
EMARTBUY GENUINE LG LG COOKIE T300 STEREO HANDSFREE HEADSET BLACK MODEL NO. SGEY0003744
i found about 4 with different names, but the same model number ranging from £4 - £8
give the guys in sound city a budget and a rough idea of what your after and i'm sure they will come up with something amazing:I will probably get a headset maybe the plantronics 367 or 377.
I have waxy ears (no amount of cleaning really helps) so I have an issue with earphones, I have some Klipsch ones which sound great but just get blocked all the time which is annoying.
Any alternatives, they need to be small and unobtrusive as well as suitable for rigorous exercise.
Do the Klipsch headphones have a particularly small hole that the sound comes out of? Perhaps a wider hole would be less prone to blockage.
If not i'm not really sure that any other type of earbud style headphones would solve the problem. As they are all basically some rubber with a hole in them which will inevitably block.
Yeah, they have a small hole. I was thinking about the powerbeats as they seem to have a bigger aperture.
My over-ears are just too big.
