I've not experienced any interference from the graphics card. There are problems with the drivers breaking regularly if you have a SSD.
how can a SSD cause that?
ive got one no interference from the graphics card here
the quality is very good and from what ive read it is a good upgrade to a xtreme music but i cant compare as my xtreme music doesnt work any more
i've got a SSD and using creative drivers at the moment for my xtrememusic which i assume is similar, and never had any issues.
thats a shame. i guess the fact that you can't remember means there's probably not much difference.
what about the connections, can you have proper surround?
I haven't been able to get surround working over optical it might be to do with the pax drivers im using
In order to get 5.1 surround working on the Xonar Essence STX, you need to select "Dolby Digital Live" in the SPDIF Out dropdown box on the Xonar Audio Center console. This will then encode all audio signals to Dolby Digital and pass this out via the optical or coaxial connection. Any speakers with Dolby Digital decoding (such as my Logitech Z906) can then play this as 5.1 surround sound. This works well on my system for all DVD's Blu-Rays and games.
If you select "PCM" in the SPDIF Out however, you are always limited to only 2 channels, as this is the maximum number of channels supported for PCM over optical or coaxial.
If you're thinking about the Creative Titanium HD PCI-E, it might also be worth giving the Asus Xonar Essence STX a good look. I have the Xonar STX and it's a fantastic sounding card.
I can't compare the Xonar against the Creative Titanium HD card as I haven't heard that, but I can say I prefer the Xonar Essence STX to my Cambridge Audio DacMagic, and it's on a par with my Arcam rDac. Both these DAC's cost quite a bit more than the Xonar, so for the price it performs very well.
Also being a Sennheiser HD595 owner I can confirm that these work very well with the Xonar, as do my newer Grado SR225i headphones.
The Xonar offers Dolby Digital Live decoding via optical or coaxial, so can support 5.1 surround sound via these connections. I currently have my Xonar powering a set of Logitech Z906 5.1 speakers in this manner, with excellent results.
Hello there. I'd like to add my opinion here.
I had both cards. But I got rid of my Xonar in the end for one reason and one reason only.
it crashed during a couple of games. I'm not sure if it was my settings/installation mind you and to be honest its probably my fckup!. But the HD is Very good. I have 6 pairs of headphones and it works well with all of them (Sein 360, Studio Beats Pro HD, Beats Control Talk, Bose etc.)
Had my xi Fi titanium for 2 days. Its a very good card. The xonar is pretty good too but the sound output for me isn't as good as the Xifi Titanium HD. I take my music pretty seriously too. But I'm not very good with my software/hardware installations lol.
What I need to figure out - is settings that people use to make the most out of it though. I knew the settings from Farooq on the forums on a thread I started here when I first bought a Xonar DG then went for the STX.
there's these pax drivers which are meant to be better and they used to be on my older x-fi so i just installed them on my titanium HD too havent tried the creative ones yet
http://www.hardwareheaven.com/pax-d...x-pcie-titanium-hd-driver-v1-60-released.html
I did read up a bit about that asus card a couple of months ago and many reviews/comparisons had the titanium hd just ahead of the STX. I think the overall view is that the titanium HD is the better choice for gaming and the asus card if music is more your thing.
yes i heard a lot about the asus cards not working well with many games, that was the main reason i veered away from those cards as i know my creative card has never has any problems in games.
i've got surround sound working correctly now playing with the dolby live settings, didnt work before it is now though
