can you spec me olivier, thanks
Stu's is good to go really.
Post your build with your favorite case (mine would be the 650D, or the Raven RV02W-EW / RV02W-EB). There maybe some room for a small SSD for the £1000. Either the £1000 or the £1300 setups. I would take a M4 instead of a OCZ due to my suspicions about their new drives. I would get a cheaper air cooler (Gelid Tranquillo), but the H2O is fine if you want a water cooler. The Gelid will give you 30% overclock. The case is a matter of preference, and for the PSU, you can take a Lepa 850W, or the OCZ, or any decent PSU >750W.
I'll post one when I get home, but it would be pretty much the same thing. I would get the Gen3 motherboard as well, even though it is expensive. I havef the kingston memory and they work as advertise (9-9-9-24
[email protected]) so that's good to go as well.
 Gainward GeForce GTX 580 "GOOD Edition" 1536MB GDDR5 PCI-Express Graphics Card  £359.99
 Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive  £173.99
 Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail  £169.99
 Asrock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155) DDR3 Motherboard  £169.98
 Corsair Obsidian 650D Gaming Midi Tower - Black  £139.99
 Lepa B-Series 850W '80 Plus Bronze' Modular Power Supply  £94.99
 LG CH10LS20 10x BluRay-ROM / 16x DVD±RW Drive - Black (Retail)  £52.99
 Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache - OEM (ST31000524AS)  £44.99
 Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)  £44.99
 Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366)  £25.99
(This can be changed during checkout) Shipping :  £13.75
  Total :  £1,294.39
