Dell Ultrasharp U2311H 23" Widescreen LCD Monitor - Midnight Grey @ £199.99 inc VAT
Your profession, your passion: No matter how you use your computer, the Dell UltraSharp U2311H 23" (58.42 cm)W Monitor brings your visuals to life in stunning widescreen clarity.
- Screen Size: 23" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 10000:1
- Brightness: 300cd/m²
- Response Time: 8ms
- Viewing Angles (H/V): 178°/178°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D & 1x DisplayPort + USB 2.0 Hi Speed Hub.
- Dimansions: 514.40mm x 184.10mm x 347.60mm
- Weight: 7.65kg
- Warranty: 3 Years Next Day Swap Out Warranty Direct from Dell.
Was £239.99 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
OcUK ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card with FREE DIRT3 PC Game @ £189.98 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required
- 450W minimum PSU recommended
- Warranty: 2 Years
- Supplied with Dirt3 PC Game (Subject to availability)
Was £197.99 Inc. VAT
Only £189.98 inc VAT.
ORDER NOW
- Weight: 7.65kg
ORDER NOW
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
