As long as they are dual slot cards then they will work in Crossfire with your sound card as I indicated in the picture I posted above.
As far as I am aware none of the manufacturers you've listed make triple slot cards.
Which card you choose will depend on the price and the only other main differences will be the type of cooler fitted and warranty. Some have more fancy (better?) coolers than others.
Some cards are supposed to be made with better quality components but you'll have to research each manufacturer for that.
As for 1GB or 2GB I suggest you read
this thread and
this thread and make up your own mind.
There are also several other threads on the same topic.
And don't forget to check the cards will fit in your case and that you have a good 750W power supply with four 6 pin PCI-E power connectors for Crossfire.
Just for clarification you want a card like this:
Not one like this:
