I've not updated my rig for what seems like ages, I used to be on a 9-12 month update schedule as new stuff came out but then other things gained priority so have had my current rig for quite a long time.
At present I'm running an [email protected] GHZ, Asus P5Q-E, GTX260, 8GB Corsair Dominator, 2xWD 360GB RE3 in Raid0, 1GB WD Black, Aego M Speakers, G15 KB and a MX518.
As you can see I've kind of missed the boat on the Sandy Bridge/SSD's
Anyway I'm looking at getting back into gaming again and have what I think is a decent budget for a new rig as I've been saving for a while but am a bit out of touch with what's currently the best kit.
I have done some research and have come up with a basic spec. but would be open to ideas if there are better alternatives.
I already have an 800D and a AX1200 PSU so the rest of the proposed rig is as follows:
CPU: 2600K
MB : Asrock Z68 Extreme4 Gen3 (maybe Extreme7 ?)
GPU : 2x MSI 580 Lightning 3072MB (if the full cover blocks appear, Zotac or EVGA if they don't as I think the warranties allow for WC?)
SSD : Vertex 3 120GB ?
HDD : WD Black 2TB
MEM : Kingston HyperX Genesis Grey 8GB 1600MHz ?
Display : U2711
Sound : No idea, using on board at the moment (last sound card I had was X-Fi Fatal1ty which is still about somewhere).
Speakers: Probably keep my Aego M's for now
KB : keep my G15 or maybe Logitech G510 ?
Mouse : Still like my MX518, anything better ?
Cooling : Apogee XT Extreme + FC Blocks for the 580's + RX360 + RX240 + 2xD5 + Gentle Typhoons.
Some of the spec I'm pretty sure on mostly the cooling as I've done a few WC rigs but the rest I'm not 100% on.
I'd like the get the CPU to 5GHz or as close as I can and I'd like kit good enough to be rock stable.
I'd also like to be able to maybe go to three monitors at a later date, would three 27's be too much for the 580's and therefore maybe go for something smaller or would the U2711 just run OK at lower
res across 3. Not run multi-monitor before so not really up to speed on it yet ?
I'm not up to speed on memory for the SB's is there a preferred speed/timing or is it not as important as it used to be ?
I played BF2 a lot and hopefully can get into BF3 the same way so would like the build completed and stable before it's released so any help would be appreciated
CPU: 2600K
HDD : WD Black 2TB
Display : U2711
