Heatsink?
Apart from that it looks ok.
You will be wanting the retail CPU then as it includes a stock heatsink, the oem doesn't.
The stock cooler is fine for 4ghz'ish
Any suggestions then on something cheapish (within £50) to tide me over for 6 months?.It doesn't come with a stock cooler because it is OEM. You just get the chip and nothing else.
Also, change the PSU to this one:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-039-OC&groupid=701&catid=123&subcat=1098
Same wattage, same price, but 80 plus gold.
Cheers mateAny suggestions then on something cheapish (within £50) to tide me over for 6 months?.
May I ask are you going to be holding this in your hands or have you already got a case?
The gold is more efficient. It will draw less power from the wall than an 80 plus bronze, but both will still output 850W.
You sure you want to go SLI? Personally, I would prefer a single 580. Unless you have triple displays.
I have read a bit into it and it seems the sli 560 TI's are performing very well for the pricing.
I had sli 8800 GTX's back in the day... Never had many issues, very few infact. Sure a driver issue here and there but never anything to make me doubt doing it again. So on that basis, I will stay with sli
Do you need 2TB right now? If not I'd get the second drive later.
I need the space chap, badly! I would even buy them for my current rig now, but will wait.
Already have over 4TB's of storage lol, so don't worry about the extra couple
Stock cooler good for a little overclocking, even though a stock 2500K is fast enough for anything.
I would also go for a gen3 Z68 motherboard.
Yea, cooling really isn't a worry right now, nor is overclocking, might have a little tinker, but until next year (after crimbo! bloody crimbo) I will be watercooling the lot.
As for the mobo... Hmmmm, will have a look mateCheers
Gainward GeForce GTX 580 "GOOD Edition" 1536MB GDDR5 PCI-Express Graphics Card £371.99
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £169.99
Asrock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155) DDR3 Motherboard £169.98
Corsair Enthusiast Series TX 850W V2 High Performance '80 Plus Bronze' Power Supply (CMPSU-850TXV2UK) £99.98
Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive £82.99
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £47.99
Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache - OEM (ST31000524AS) £41.99
(This can be changed during checkout) Shipping : £10.00
Total : £996.91
Your build is under £930 if I read correctly.
The 560 ti sli's are almost the same price but perform better... £348...
They sure do, but I haven't seen a game a 580 can't handle. If you game on single display, SLI is OTT and more complicated. Just my $0.02.
I like 8GB. I have these sticks, and I disabled virtual memory (and hiberation, that was taking 6GB of SSD prime real estate). That's useful on a SSD, especially a small one. Can always move the page fil on a hard drive though.
These zalman, iirc, are quite noisy and spin like crazy. Double check.
So noise really isn't an issue lol.
