I love my Lancool, I think there's only a few others out there that I'd even consider replacing it with...
Raven as Stulid pointed out above.
I like the Fortress 3, but this brings in the need for different motherboard and various other space conscious decisions...
I'd look at most of the Corsair's..
Maybe the NZXT Phantom
Fractal R3
Their basically my choices...
Saying that, if you're not going to watercool, get the Lancool, honestly, it does absolutely everything you need, and from personal experience was dead easy to build in (only had problems with the 8pin power cable but that still wasn't a big deal...)
Take the savings you'll make over the Raven and invest in a SSD, or better GPU
Edit: K62 may be the older model, but it is sooo much nicer looking than the K63
As for Blue in a case, maybe look into the Phantom.. or just buy some aftermarket fans with Blue LED's...
kd
