Hey Guys
Just to inform you that we now carry stock of EK Waterblocks that use the EN Nickel Plating method.
As many of you are aware, EK recently had an issue where some of their nickel plated products suffered from flaking, this new method of nickel plating is a much more expensive process and has proved to be much more hard wearing.
We are aiming to refresh our catalogue with the full range of EN Nickel Plated products from EK as availability increases.
there is also a plethora of new and reintroduced EK stock inbound
EK Supreme LTX CPU Waterblock - Nickel Plexi **EN Nickel Plated** @ £32.98 inc VAT
EK-Supreme LTX water block for all socket CPU's has been designed for the hardest enthusiast user. The LT (Light) version has beed designed to lower the production costs and offer EK quality branded CPU water block at the best price.
The base plate is made of nickel plated electrolytic copper lapped and polished to +/- 0,0007 mm flatness. The top is made of quality Acrylic material.
The EK-Supreme LTX cooling engine uses fin design. The water accelerates through 46 very thin channels, which gives extreme cooling surface. The copper base is also very thin, which gives very short distance for temperature to transfer from CPU to water.
Supported sockets:
Processor compatibility:
- Intel Socket 775,
- Intel 1366 socket
- Intel 1156 socket
Only £32.98 inc VAT.
ORDER NOW
EK Supreme LTX CPU Waterblock - Nickel Acetal **EN Nickel Plated** @ £32.99 inc VAT
EK-Supreme LTX water block for all CPU socket is a successor of Supreme LT and designed for the hardest enthusiast user. The LTX (Light xtreme) version has been designed to lower the production costs and offer EK quality branded CPU water block at the best price.
The base plate is made of nickel plated electrolytic copper lapped and polished to +/- 0,0007 mm flatness. The top is made of quality POM Acetal material.
The EK-Supreme LTX cooling engine uses fin design. The water accelerates through 46 very thin channels, which gives extreme cooling surface. The copper base is also very thin, which gives very short distance for temperature to transfer from CPU to water. The main improvement made compared to Supreme LT version is that LTX has deeper channels (0,5mm deeper), therefore allows greater flow and better performance.
Supported sockets:
- Intel 775 socket
- Intel 1366 socket
- Intel 1156 socket
- Intel 1155 socket
Only £32.99 inc VAT.
ORDER NOW
EK GTX 6970 Full Cover Waterblock - Nickel Plexi **EN Nickel Plating** @ £67.98 inc VAT
A Full cover block for reference design Radeon HD6970 graphic card.
High performance water block for Radeon HD6970 reference graphic cards. Please check our www.coolingconfigurator.com online compatibility system to see if your card is compatible.
Base is made of nickel plated electrolytic copper. Top is made of quality acrylic material. The sealing is preformed by quality rubber washers. Block is mounted with enclosed M3x8mm DIN7985 screws.
Fittings can be used on both side of the block (up and down) and 2 plugs are enclosed!
Enclosed:
- water block
- mounting mechanism
- thermal pads
Only £67.98 inc VAT.
ORDER NOW
EK CoolStream Radiator XT 120 (120.1) @ £24.98 inc VAT
Quality at EK level and an optimal price-performance ratio make these EK-CoolStream RAD XT radiators unique. The new radiators feature, besides their great design and high build quality, great cooling performance. The copper fins are specially designed for Ultra-silent fans (with low Airflow). The parallel coolant channels reduce flow resistance to a minimum. On both sides of the radiator the M3 threads are integrated to allow fan installation on both sides and radiator mounting. The radiator has integrated G1/4" threads, allowing installation of virtually all common fittings. Please note: Over-tightening of the screws may damage the radiator. Always take care that the screws do not damage the radiator. Damages of the product because of improper use are not covered by the warranty!
Technical details:
- Material: Copper fins, Brass chambers
- Dimensions (LxWxH): 154x119x47mm
- Connection threads: G1/4"
- Weight: Approx. 630g
- Fan installation: 4 x M3 threads on both sides each (for 1x120mm fan each)
- Pressure tested: 8bar
Enclosed:
- 1x EK-CoolStream RAD XT (120) radiator
- 4x M3 x 30mm screws
- 4x M3 x 35mm screws
Important: The included screws may be too long for some applications. Always be sure to screw them in only so far that the radiator is not damaged.
Only £24.98 inc VAT.
ORDER NOW
EK-FC580 GTX Backplate - Black @ £19.99 inc VAT
Retention backplate made of black painted aluminium for EK-FC580 GTX water block.
Backplate serves as aesthetics add on.
This backplate is compatible only with Reference PCB design Nvidia 580 GTX cards in combination with any of EK-FC580 GTX waterblocks.
Only £19.99 inc VAT.
ORDER NOW
EK-DDC X-TOP Rev.2 Acetal Pump Top @ £17.99 inc VAT
#1 DDC TOP currently on the market.
Compatible with all DDC style pumps.
Increases head pressure and improves flow.
gives the user the option to use standard G1/4 watercooling fittings.
EK-DDC X-TOP rev.2 Acetal
Threads: G1/4
Dimensions: 67×62×20mm
Included:
- 4 M4x24mm screws
- Weight of the packet 160g
- fittings not included
Only £17.99 inc VAT.
ORDER NOW
Supported sockets:
- Intel Socket 775,
- Intel 1366 socket
- Intel 1156 socket
ORDER NOW
Supported sockets:
- Intel 775 socket
- Intel 1366 socket
- Intel 1156 socket
- Intel 1155 socket
ORDER NOW
Enclosed:
- water block
- thermal pads
ORDER NOW
Technical details:
Enclosed:
ORDER NOW
ORDER NOW
Threads: G1/4
Included:
- 4 M4x24mm screws
ORDER NOW
