Its not monitor related. As if I literally pull the cables from the monitors and switch them, then it will switch the other to black and white.
Yeah I've tried all the possibities. The monitors just react differently depending on how many cables are plugged in.
So they'll both work with each tv on their own, then once I plug them both in at the same time the picture from whichever monitor is plugged into the DVI port will suddenly turn either black and white, or off. Depending on which DVI port, which also makes it strange as the two ports don't act the same.
