- 26 Aug 2004
I flashed my DG834GT with DG834GT_V1.03.22_DGTeam_1018_eng_adsldrv026.img via Google Chrome and it worked fine!
So you are the one! ;DI flashed my DG834GT with DG834GT_V1.03.22_DGTeam_1018_eng_adsldrv026.img via Google Chrome and it worked fine!
I tried using that method and the netgear recovery software but failed,i ended up loading a pc with linux and having to type commands in.Took me about a dozen goes as i kept making typosI think you can unbrick these routers. From memory, you power it up, keep the reset button pressed in, unplug the power lead whilst still holding the reset for 15 seconds, then plug the power back in.
You must be lucky as i `bricked` my router using this version and have read that `a lot` of other people did the same
How did you do it please?Step by step would be great,anything special have to be done?Apart from using chrome i mean?
and set a static IP on your PC.
Is there anything different about the firmware you have flashed? Is it better for sync and stability than 23o?
I have used the Netgear DG834v4 but I have found that it can't hold lower than 3dB. What are your line stats?
Does that hold at night?
I have tried putting 26 on it but it bricks. Is there anything I can do. Can you link me to the firmware you used?
Thanks.
