I'm going to go insane, MSI Z68A-GD80 (G3)
Permabanned
5 Sep 2010
fraggin UR ass
What the **** is wrong with this mobo, it's the buggiest BIOS i've ever met, i don't think i want to meet it ever again on a dark night.
There is no mouse control, the click bios 2 says it doesn't support my main board :eek:
I've done updates via the live update, no better.
But the worse thing is both my gpu's are running @ x8
Anyone got any suggestions?
You can't navigate the bios, the mouse is fine in windows, so we will strike the info off.
The mobo runs 3x @x16 :p
now i'm crying :D
I bet it dont;)
You win.
Slots
2x PCIe 3.0 x16 slots (PCI_E2, PCI_E4)
1x PCIe 2.0 x16 slot (PCI_E5)
PCI_E2 supports up to PCIe x16 speed (when PCI_E4 is empty) or PCIe x8 speed (when PCI_E4 is installed)
PCI_E4 supports up to PCIe x8 speed
PCI_E5 supports up to PCIe x4 speed
You win.
Slots
I don't even have 1 running @ x16, in theory there are 3 x16 slots so says the manual.
I'd be happy if just 2 ran @16 or even 1.
So you are saying they'll both only run @ X8
When you have one card installed in PCI_E2 (the first Blue slot from the top) PCI_E1 being the little Black one above it, on its own with no other cards installed it operates at 16X
When you add a second card into PCI_E4 (the next Blue slot) the bandwidth is divided to 8X and 8X
I will quote from MSI off the mobo info that i got with it.
3 xPCI Express x16 slots, enjoy the power of multi-graphics, more PCI-E bandwidth than other Z68 MBs
The UEFI bios is a piece of doggy doo.
I'm going to do a whole new fresh install tomorrow, as i give up with this one.
I've seen that before about the x8 tests i'll just have to put up with that ;)
I have my freaky moments.
Now that's just cute, decides to share hot water bottle with them :)
You can quote that all you like, it doesn't change the facts that the other 16X PCI-E slots are not fully wired.
Actually look in the second Blue slot and see if the little gold fingers go all the way across it.
http://www.msi.com/product/mb/Z68A-GD80--G3-.html#?div=Detail
- PCI_E2 supports up to PCIE x16 speed when PCI_E4 is empty, or PCI_E2 will support up to PCIE x8 speed when PCI_E4 is installed
- PCI_E4 supports up to PCIE x8 speed
don't feel sorry for the little black thing, it has other coloured friends nearby.
it would be a lot worse if it was sandwiched between the two large black things.
If you look at the rear of the motherboard you can see that PCI_E2 is fully connected, PCI_E4 only has connections for x8 and PCI_5 only has connections for x4.
When cards are installed in both PCI_E2 and PCI_E4 half the connections for PCI_E2 are disabled to supply the bandwidth for PCI_E4.
