Hi, I need some advice.
I'm trying to overclock my i5 2500k using the UEFI BIOS on the ASRock Z68 PRO3.
I've got to 3.8GHz so far, but the problem I'm having is the CPU Core Voltage, when I set it to Fixed Mode and a value, say 1.200, it never changes to that value, it's always well under. Like 1.144V.
When I change it to 1.240, it changes to 1.184V.
Any ideas? Also, should I be using offset mode instead and what is the difference?
Thanks in advance.
Thanks in advance.
