- 10 Sep 2008
- Bangor, Northern Ireland
lol.
I can tell by the pixels.
lol.
Errr, take a look at both images... there's a huge difference, the edited one shows massive amounts of errors compared to the other photo.You know this doesn't work right?
Here's with the edited one.
http://errorlevelanalysis.com/permalink/326b97c/
That's because it's all from the same image, it works based on jpeg compression differences in images which will vary depending on how many times each has been saved.
That's the entire point! The second one is a good example of an image that's been processed and saved, the original one, shows little evidence of it being a composite of different images.It's all brighter, even the background.
The face of the guy that's been moved isn't exactly bright.
See, this is a good version of what should appear of that pike had been added to the image and the image edited for things like shadows and so on. The pike photo has none of that in it at all.Look at this example I've just seen,
Original Image - http://imgur.com/Apm1Ol&HbFwt
Edited version being checked on error level analysis - http://www.errorlevelanalysis.com/permalink/8411259/
But the original photo doesn't have that brightness in it. It's comparable to the edited version which we know has been edited...The second one isn't a composite of different images. Like Raikiri said, it's just been resaved.
Resave any jpeg without editing it and you'll get a brighter result in error level analysis (more so if it's not saved at 100% quality).
Obviously the shutter and the car have been photoshopped in this!
http://www.errorlevelanalysis.com/permalink/2fe0881/
lol
And personally, I don't think the original photo in this thread has been photoshopped.
What it's specifically looking at is the image degradation due to JPEG compression, so everytime you save it, it'll become brighter and brighter. It'll also highlight differences between composite images that may have been saved different numbers of times. Less brightness means that it's likely it hasn't been edited in anyway (requiring another save).It's brighter, must be shopped.
Are Pikes not freshwater fish? Looks like a saltwater environment to me.
Edit:
The original image has very little areas of intense brightness, but even just that one recompression of the unedited image makes the whole image substantially brighter which gives credence to the orginal image not having been edited in anyway.
Ooooh that's cheatingLook at this;
This has about as many areas of 'intense' brightness as the original photo
Deffo shop ,
You would be covered in crap lifiting a 31Lb Pike , and you would also have to support the fish with your right hand under and around its gills showing your hand under the fish.
Ooooh that's cheatingtry it with the pike in colour.
