850w PSU
Stick with quality brands, like from Corsair, Antec and XFX.
I would also remove the name in the second post ;)
if you really want an 850W PSU this is the best your going to get for a resonably low price:
OCZ Z-Series 850W '80 Plus Gold' Power Supply
good brand, modular, very energy efficient and highly rated by jonnyguru, what more could you ask from it when its under £100
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story5&reid=167
(the main bad thing in the review was the price, but OcUK have fixed that :))
however, its quite likely that you dont need something that powerful, so if you tell us your PC spec (theres a free program called CPU-z which can do that for you) and what upgrades you plan on doing in the near future then we can recommend you a PSU based on that
I can recommend that PSU. Got it when I RMAd my 800W OCZ and it's been great running a Core i7 at more volts than is good for it and a couple of GTX 260s
