Fault codes aren't always accurate.
My emissions light came on once, came back as EGR mass too high, all tests pointed to yes the EGR air mass was too high.
That is what the fault code was, thats as much information DIS was able to give us.
So even with fault codes read, you still won't know the real issue.
[TW]Fox;19885003 said:The fault codes will tell you exactly why the light is on. It won't tell you the problem, but it will tell you why the light is on and once you know this, you can begin to work out whats wrong.
