** ATI 6950 EPIC DEALS & 6970 & 6990 BACK IN STOCK! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Yes we've got some great deals for you guys on 6950 cards and those who have been waiting for the 6970 and 6990 they are now back in stock, though very limited in numbers:-
MSI ATI Radeon HD 6950 OC Twin FrozR III Power Edition 2048MB GDDR5 PCI-Express Graphics Card with Dirt3 PC Game @ £205.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Core Clock: 850MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5200MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required
- 450W minimum PSU recommended
- Warranty: 3 Years
- Supplied with Dirt3 Download Voucher (Subject availability)
Was [£249.99] Inc. VAT
Only £205.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6950 FLEX 2048MB GDDR5 PCI-Express Graphics Card with upto 5 Monitor Support & with FREE DIRT3 Game @ £215.99 inc VAT
Most graphics cards based on AMD technology require the third monitor in an Eyefinity set-up to be a DisplayPort monitor, or connected with an active DisplayPort Adapter. The SAPPHIRE FleX family can support three DVI monitors in Eyefinity mode and deliver a true SLS (Single Large Surface) work area without the need for costly active adapters. The first two monitors are connected to the two DVI ports and the third to an HDMI to DVI cable (supplied) with no extra hardware required.
The SAPPHIRE HD 6950 FleX is now the highest performing card with this feature, allowing gamers to use low-cost DVI monitors for all three screens. Additional monitors can be added to the setup, but must be DisplayPort connected.
Like the standard HD 6950, the SAPPHIRE HD 6950 FleX Edition boasts true DX 11 capability and the powerful configuration of 1408 stream processors and 88 texture processing units. With its clock speeds of 800MHz for the core and 1250Mhz (5 Gb/sec effective) for the memory this model brings multi-screen enjoyment to even hard-core gamers.
Features:-
- Core Clock: 800MHz
- Memory Clock: 5000MHz (Effective)
- Texture Units: 88
- ROPS: 32
- Display Connectors: 1x Dual-Link DVI-I, 1x Single-Link DVI-D, 1x HDMI 1.4a, 2x Mini-DisplayPort & DisplayPort 1.2
- HDCP Capable
- ATI Avivo HD
- 2x 6pin PCI-E power connectors required (Power Adapters Provided)
- Warranty: 2 Years
- Supplied with Mini-DisplayPort too HDMI Cable
- Supplied with 1.8M HDMI High Speed Extension Cable
- Support 3 DVI monitors in Eyefinity mode, right out of the box! Up to 5 monitor Eyefinity mode support with Sapphire Flex.
- Supplied with Dirt3 PC Game (Subject to availability)
Was [£239.99] Inc. VAT
Only £215.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6950 TOXIC 2048MB GDDR5 PCI-Express Graphics Card with FREE DIRT3 Game @ £224.99 inc VAT
The SAPPHIRE HD 6950 TOXIC Edition ships with clock speeds of 880MHz for the core and 1300 MHz (5.2 Gb/sec effective) for the memory, making it the fastest production HD 6950 on the market. This has been achieved by building the card on a high specification PCB with digital VRMs for excellent power regulation and 8 + 6 pin power connectors. It has a high performance cooler featuring a Vapor Chamber, blower fan and a new perforated backplate to increase airflow out of the system case.
Features:-
- Core Clock: 880MHz
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Only £224.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
The Sapphire HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- 1x 8pin and 1x 6pin PCI-E power connectors required (Power Adapters Supplied)
- 500W minimum PSU recommended
- Warranty: 2 Years
Only £319.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6990 4096MB GDDR5 PCI-Express Graphics Card @ £569.99 inc VAT
Designed for the power gamer, AMD Radeon HD 6990 graphics cards include AMD's second-generation, Microsoft DirectX 11 capable architecture, advanced image quality features for the best looking games, and AMD PowerTune intelligent technology to enable higher clock speeds and faster gaming. The AMD Radeon HD 6990 offers the ultimate in immersive HD gaming and computing with native support for up to five displays using AMD Eyefinity multi-display technology, with six display support possible via DisplayPort 1.2 components available for purchase later this year. The AMD Radeon HD 6990 graphics cards also feature a dual-BIOS toggle switch, allowing enthusiast gamers to unlock the card and rev up the clocks and voltages for even more performance. Finally, AMD HD3D technology provides a cutting-edge stereoscopic 3D gaming and movie experience, thanks to HDMI 1.4a support.
Features:-
- Core Clock: 830MHz (880MHz OC Mode)
- Memory: 4096MB GDDR5
- Memory Bandwidth: 320GB/sec
- Processing Cores: 3072
- Texture Units: 192
- ROPS: 64
- Display Connectors: 1 Dual-Link DVI & 4x Mini-Display Port (Adapters supplied to HDMI/DVI)
- HDCP Capable
- ATI Avivo HD
- Maximum Power Consumption: 450W (Typical 400W)
- 2x 8pin PCI-E power connectors required
- 700W minimum PSU required (1000-1200W recommended for Crossfire with with four 8 Pin connectors)
- Warranty: 2 Years
Only £569.99 inc VAT.
ORDER NOW
That Toxic 6950 is probably pretty much exactly the same speed as a 6970 would be like 1-2 fps slower I guess.
Yes its only dis-advantage is its 300MHz slower on the memory and as the memory is quad-pumped that means there is literally zero performance difference, even at 2560x1600 your looking at just 1-2fps.
Also this is a Toxic, they normally overclock like demonds. :D
The toxic even comes with an altered bios that may or may not unlock the extra shaders out of the box!
It is a very special card and this price is only valid whilst were waiting for stock.
If I was buying a card right now, this would be it. :D
I've just bought two refurbed 480s, you've already taken my money :D.
Feel free to pay me for helping you market this product though :D
The GTX 480 for the money is unbeatable though, but its not a current card and are very rare, so congratulations on getting a pair. :)
Oh fantastic....only ordered a 6850 on Saturday from you for almost the same money as the twin frozr !
Not happy now !
How much better are these than a 5870? I'm out of touch with gfx cards :o
Hi there
Its as follows:-
6850 - 5830 - GTX 460 - GTX 560
6870 - 5850 - GTX 470 - GTX 560Ti
6870 OC - 5870 - GTX 470 - GTX 560Ti
So a 6950 standard has the edge over a 5870 and an OC 6950 like the Toxic is quite a bit faster, but your not talking a radical performance boost.
I'd probably not do it if your 5870 is playing your games I'd wait for the next refresh at end of the year. :)
I admire your honesty there Gibbo. I have a 5870 myself and have been debating for a while now about whether to upgrade to a 6950. Will hold onto it for the refresh. That's an order for you guys come the end of the year. :)
Really tempting prices though!
6950 toxic is tempting as I recently upgraded from 1920 x 1200 to 2560 x 1440(u2711) and have a msi twin frozr 5850(slight oc 750/1000 recntly playing with overdrive) only got it before chrismas, trying to stop myself and wait till the new cards are released by amd and nvidia.
the 6950 will be bottlenecked as I have a q6600@3ghz(have a q9450 which I'll put in there once I get around to cleaning my pc(quite dusty, have a air duster and been meaning to clean for ages but been lazy), been wanting to upgrade to a i2500k but no job for 15months now(only bought the u2711 as my 24inch monitor went on the fritz and only could use it for like 30mins - 1hr before having to turn it off for abit).
6950 toxic(£225), 5850 vapor-x(£120) to xfire with the msi twin frozr ii 5850(whats 5850 xfire vs single oced 6950 like?) or just stick it out with the single 5850 for a few more month?
