Any rammifications for buying a repaired Cat D?
Caporegime
18 Oct 2002
Back in East London
Would there be any problems buying a Cat D? I've just seen this advert and it looks like a good buy until I read the Cat D bit and my gut tells me "no".
Would you buy/trust a repaired Cat D? Would the insurance be higher? Any thing else to bear in mind?
A cat D is where the repair cost exceeds the car value minus its salvage value.
This means a small dent on a 500 quid car or a big smack on a more expensive car.
Just doesn't sound good really does it OP?
As for cat d's in general, isn't this normally cosmetic damage?
It's down to how much the repairs will cost and how much the car is worth. If the car is fairly new then it'll take quite a lot of damage to write off the car.
On the flip side my last car was recorded as a Cat C write off, despite it still being drivable.
EDIT: Beaten by the Fox.
[TW]Fox;19888393 said:
8 grand for a cat D 3.5 year old Focus?
I wasn't expecting to pay that much, if I were to go for it.. but compared to other 2008 ~10k 1.8 focus's, it's advertised cheaper! :)
I'm also possibly the least informed person of what the value of a car should be tbh.
edit: If it wasn't a cat D, would you be saying the same thing? :)
glass' valations give an accurate idea of a car's worth assuming its in good nick (ie value of that model/age/milage, not the specific car). Car dealers use it as their bible....literally - they spend £100s yearly on this bible looking book from Glass.
Cat D, personally I would avoid but i'm not sure why. Probably more trouble than its worth.
The last car of mine that took a smack was never quite the same after something hit it from behind. Lots more creaks and rattles started appearing afterwards.
I'd rather get a used car that had a better chance of not having been pranged already.
The advertised price is along the lines of what I would expect to pay for something that's not a Cat D.
Am I the only person who thinks that the rear doors and rear wing aren't quite the same colour?
Passenger side doors are a different colour to the surrounding bodywork, I reckon.
I'm finding it difficult to guess which are the original bits. The lighting doesn't help with that, mind you.
It appears the ad has been removed. For anyone interested, it was a 2008 1.8 "Titanium" Focus, with 10k on clock, Cat D, £8,000.
No, I haven't bought it :p
edit: nope, it's back.
There are sooooooooo many focuses for sale for 8 1/2 grand and under why bother with a cat d one ? The questions you are asking now and the doubt you have should tell you all you need to know.
My old 146 was a Cat-D, it was cheaper to buy than an identical non cat-D and it would have been cheaper when sold if I hadn't blown it to pieces and weighed it in.
Nothing wrong with a cat-D as long as if it was crashed, the repair work is safe. For example; a rippled member in the shell, a strut, a crash structure etc where it has been pulled into shape is bad. A properly shaped shell with a new crash structure fitted is good. Get someone who knows what they are looking at to inspect it.
I'm with the above though, no shortage of Focus. Just find a cheap one.
