I've decided to go with building my own instead of pre-built.
Question is as the title states, which do you think is better?
The general spec is a MSI P67-GD53, I5 2500k 3.3, and a MSI 570GTX Ti twin FrozR II.
I've seen the Video for installing a H60 and seems simple enough so ease of installation etc isn't a factor.
Oh and the case is going to be a CM 690 II lite.
Aside from which is the better cooler, I notice Corsair recommend the 120mm fan to push air into the case instead of the standard exhaust. Well the case as standard only comes with one more additional fan on the front and this also puts air into the case not out.
So the question is, would I need a top/side exhaust 120mm fan in addition?
Thanks!
Ross
Thanks!
Ross
