- 23 Mar 2011
hey guys!
i have this psu
http://www.overclockers.co.uk/showproduct.php?prodid=CA-003-XF
and this motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-054-AK&groupid=701&catid=5&subcat=1990
When i connected it all up the psu has 2 4pinn connectors that join up to make the 8 pin. however one half fits perfectly to the motherboards 8 pin socket and the other 4 pins shapes dont look like they match up if that makes sense, but its still connected at the moment!
should i take the 2nd 4 pin half out and just use the 4 pins that match up to the motherboard (sorry if this is hard to follow, trying to explain it best i can)
if so how can i cap off the remaining 4 pins from the psu, or is that not necessary.
thanks for any help given, it just doesnt look like it sits properly as if the 2nd half isnt ment to be plugged in, dont want to damage my new mobo!
thanks!
i have this psu
thanks!
