as far as i could tell it added no extra load.
my only issue with this is the nicking of other people builds and work.
as this can then lead to people claiming they done someone else build.
Until /lb command shows otherwise
I don't think it's right to copy the server without the general consensus of the users tbh.
Until /lb command shows otherwise![]()
There's no way to police it - the data goes to the user when they're on the server normally. What they do with it then is up to them.
You're forgetting that minecraft iz srs biznis.
Whats this mod called? Link?![]()
The mod will not cause any additional load on the server because it never actively requests anything. It lets Minecraft do all the loading and buffering and then right before MC overwrites a buffered chunk that is no longer needed, it saves this chunk to disk. This will only slow down the client a bit when your HDD is too slow. It also saves the complete chunk buffer when stopping downloading or disconnecting.
Sorry I've not been about too much. I've been mega busy at work on a new shift rotation & my back started playing up again. Hope to be on at the weekend![]()
