Hi there
Alongside our truly amazing THIS WEEK ONLY OFFERS were also gonna be doing throughout today some PAYDAY Deals on a small selection of products, these shall be posted throughout today and remain active until this weekend:-
Asus Axe Square Limited Edition Gold CPU Cooler (Socket LGA775/LGA1155/LGA1156/AM2/AM3) @ £19.99 inc VAT
Axe Square AMAzing features a 120mm LED fan, five copper C-shaped heatpipes, a copper base and a large-scale heat dissipation surface area of up to 5500cm2 to facilitate highly efficient heat transfers in order to provide enthusiasts worldwide with the ultimate cooling experience.Ultra Silent at 16 dBA and Power Savings
Equipped with the PWM function, Axe Square AMAzing is able to adjust the fan speed according to the CPU’s temperature—providing users with the optimal operating environment at a mere 16 dBA, as well as helping to conserve energy and delivering CPU stability.
Amazing Gold-Aureate Design with Luxury Packing
Axe Square AMAzing is the latest model in the limited AMAzing series, and takes center stage with its stunning gold-aureate color; which juxtaposes with the black nickel-plated surfaces of unique axe-shaped design for the ultimate in aesthetic appeal. Moreover, this stunning Axe Square AMAzing comes in an extremely luxurious packaging with a limited-run identification card that ensures the fine quality of the amazing Series.
- Dimensions: 139 x 133 x 130 (W x H x D)
- Nickel plater for stunning looks
- Supplied with high quality thermal paste
- Noise Level: 16dBA
- Fan Speed: 1400 RPM
Was [£31.99] Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Asus Royal Knight CPU Cooler (Socket LGA775/LGA1155/LGA1156/AM2/AM2+) @ £17.99 inc VAT
Royal Knight provides for an advanced thermal solution, including 6 pure copper heat pipes for efficient heat transference; a 120mm LED fan with a top-flow design for maximum air-flow; last but not the least, twin wing-shaped copper fins that expands the heat exchange area for excellent thermal performance.Equipped with a 120mm LED fan, Royal Knight not only provides maximum air-flow, but also ensures a quiet computing environment with operating levels of only 22 dBA. This is due to the PWM function, which can automatically adjust the fan speed by CPU's temperature - allowing gamers to fully immerse themselves into their games without other distracting noises.This latest Royal Knight presents itself in a retro-chic British Chevalier stylized outlook - integrating a crown, a coat of arms and an eagle that embraces the core spirit of the Knight Series. With the most advanced thermal solution to support impressive overclocking capabilities, coupled with such fine aesthetics, the stunning Royal Knight is truly a crowd pleaser in terms of looks and performance.
- Dimensions: 131 x 140 x 138mm (W x D x H)
- Fan Speed: 800 - 1300 RPM
- Heatsink Material: Copper
- 4-pin PWM plug
Was [£29.99] Inc. VAT
Only £17.99 inc VAT.
ORDER NOW
Corsair Hydro H80 High Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3) @ £79.99 inc VAT
Corsair Hydro Series liquid CPU coolers provide a compact, easy-to-install, and maintenance free alternative to bulky, noisy air coolers, efficiently cooling and protecting your high-performance Intel® or AMD® CPU. The H80 features a double-thick radiator to maximize the surface area available for heat dissipation and dual performance matched fans. It also includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs.
The Corsair Hydro Series H80 high-performance CPU cooler fully supports Corsair Link Digital connections, so you can be in complete control of your cooling. Monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles*.
* Requires the Corsair Link Commander, sold separately
The low-profile integrated pump and cold plate includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs. The cool white LED display lets you know at a glance which profile is being used.
Double-up for excellent cooling
Featuring a double-thick radiator to maximize the surface area available for heat dissipation, and dual, performance matched fans, the H80 delivers cooling performance that lets your CPU keep its cool, even when pushed to the limit. And with all this cooling performance, the compact design still fits virtually any case with a 120mm fan mount.
- Corsair Link™ Digital compatibility means that you can be in complete control of your cooling.
- Push-button fan control so you can select the fan speed and cooling performance that best suits your needs.
- Double-thick 120mm radiator for increased surface area and cooling potential.
- Two all-new 120mm fans optimize static pressure and airflow for amazing performance.
- FEP tubing provides extraordinarily low coolant evaporation levels.
- A new improved micro-channel cold-plate design more efficiently transfers heat.
- Quick and easy installation brackets make it easier than ever to upgrade to watercooling.
- Includes mounting hardware compatible with all modern CPU socket designs
- Radiator Dimensions: 120mm x 38mm
- Fan Dimensions: 120mm x 25mm
- Fan Speed: Up to 2600 RPM
- Air Flow: 46 - 92 CFM
- Fan Noise: 22 -3 9bDA
Was [£84.98] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
ORDER NOW
- 4-pin PWM plug
ORDER NOW
ORDER NOW
