Convince me not to GTX 570 SLI @ 1080p
its a waste and time and money easy
enjoy 570, wait till next gen
its not as if you will have any noticable difference when you add a 2nd
Go for it, running sli 470's here at 1920x1200, very good gaming setup. If you can source the other card secondhand it always helps. Make sure the psu is upto the job as well.
What PSU are you running? Would like this eventually. Running a Zalman cooler on mine if it makes any difference...
Corsair HX850w. The zalman may cause issues depending on your board and case, due to it covering board slots.
Pic of my setup.
I could move the psu to the top of the case, if the lower card had an aftermarket cooler attached.
I won't convince you, but I can give you negative views of it:
a) You won't be able to run Shogun 2 with max settings at 1080p. The built-in benchmark would refuse to run, giving you an annoying error message of "insufficient vram", while the game would actually reduce your graphics settings in stealth. You could override the script file to avoid such problems, but you risk suffering from lag spikes due to vram shortage.
b) You shouldn't be able to max out GTA 4 because the game engine has a stupid vram check. You'll need to hack the game in order to bypass the vram check. Again, you risk suffering from lag spikes. Also I read somewhere else that if you install any mods such like ENB, 1.25GB vram would lag like hell.
c) You also risk getting lag spikes in Metro 2033, Crysis, Crysis 2 DX11 with high res texture, future games etc due to vram shortage if you set max settings.
d) If you lower your graphics settings to a certain threshold below which the vram usage is safely below 1.25GB, in most cases you get a framerate much higher than 60 fps. Unless you are using a 120 Hz monitor for 3D or something, I regard it as wasting GPU power.
I don't recommend putting GTX470 into SLI, unless you can get it for a cheap price.
Just personal opinions. Feel free to troll.
Personally. If it was me I'd pump for a new monitor
1900 x 1200 / 1080 is OK but try a 2560 x 1440 monitor with a single 570 and there is no going back.
Well happy here.
True, luckily i picked both cards up for £259.00 in december last year. No issues with v-ram, but then i dont play any of the games youve listed.
Resolution?
PS. Just followed the linky.
TBH. I'm really not that impressed with big daft plasma screens or how much things cost in total.
I've spent more than £2000 on a needle for my record player in the past. Been there. Got the shirt. Not big. Not clever.
I sit 2 feet away from my screen. 27" is good 30" is too big. I know. I tried.
IMHO of course
I'm in the same boat as you easyrider!, I'm thinking of adding another 580 to my set up just cause I want/can do it no other reason... But is it worth another £300 for an extra 30fps,lol.
Resolution?
IMHO of course
I didn't post my thread to impress. I posted to share the build for people who were interested.:rolleyes:
I have a 24" monitor BTW
