Hi Guys
Thought I would highlight the deals we have on at the moment.
some very attractive prices on watercooling components.
EK Fullcover GTX 580 Waterblock - Nickel Plexi @ £65.18 inc VAT
A Full cover block for reference design GeForce 580 GTX graphic card.
High performance water block for GeForce 580 GTX reference graphic cards. Please check our www.coolingconfigurator.com online compatibility system to see if your card is compatible.
Base is made of nickel plated electrolytic copper. Top is made of quality acrylic material. The sealing is preformed by quality rubber washers. Block is mounted with enclosed M3x8mm DIN7985 screws.
Enclosed is also a GPU reinforcer. A metal plate which is mounted around the GPU with M3×4 screws and reinforces the PCB for perfect GPU contact with Water block without unwanted PCB bending.
Fittings can be used on both side of the block (up and down) and 2 plugs are enclosed!
Enclosed:
- water block
- GPU reinforcer plate
- mounting mechanism
- thermal pads
Was £69.98 Inc. VAT
Only £65.18 inc VAT.
ORDER NOW
EK GTX 590 Full Cover Waterblock - Nickel Acetal @ £92.99 inc VAT
A Full cover block for reference design GeForce 590 GTX graphic card.
High performance water block for GeForce 590 GTX reference graphic cards.
Base is made of nickel plated electrolytic copper. New cooling engine involves thin fins cut into copper, providing extreme cooling performance and excellent flow over both GPUs.
Top is made of quality black POM Acetal material. The sealing is preformed by quality rubber washers withstanding temperature range from 0 up to +80 degrees Celsius. Block is mounted with enclosed M3x8mm DIN7985 screws.
Enclosed:
- water block
- thermal pads
Was £96.98 Inc. VAT
Only £92.99 inc VAT.
ORDER NOW
Hardware Labs Black ICE GT Stealth 240 Radiator - black - XFlow @ £38.20 inc VAT
For uncompromising performance are the new Black Ice ® GT Stealth radiators. The radical redesign of the Black Ice ® core technology increases efficiency, this currently latest and most powerful Black Ice generation, again significantly. So that the radiator for both projects and Overclocking Silent PC is suitable. When XFlow's offered here are not the connections on one side, but face each other diagonally. The advantage of this variation is especially noticeable in water cooling systems, which have a strong pump. The cooling medium flows directly and without change of direction through the radiator. The performance is increased significantly once again. The new arrangement of the lamellae ensures optimum cooling in a confined space. By using 45% thinner copper fins to get there with 50% less pressure - at the same time double-density disk. 30 fins per inch increase dramatically, and ensure the surface of a heat transfer that has no equal. Compared to the Black Ice ® Pro can be delivered faster to heat up to 20%. Due to the better heat transfer capability can slowly rotating fans are used. The cooling capacity of the system is maintained and the noise level can be further reduced significantly. The processing and very specifically in the painting of the radiators is top notch. M4 thread and the G 1 / 4 thread for the connecting holes ensure easy installation and maximum compatibility.
- Brass radiator with copper fins soldered
- G1/4" Thread
- Fan Mounting with M4 thread (both sides)
- Size: 290x135x30mm
Was £39.98 Inc. VAT
Only £38.20 inc VAT.
ORDER NOW
Hardware Labs Black ICE SR-1 360 Radiator @ £71.99 inc VAT
The Black Ice® SR1-360 bridges the gap between ultra-stealth and extreme high performance allowing it to effectively utilize sub-1000 rpm fans and scale performance up to 2000rpm. Ultra-stealth operation with increased thermal capacity, and from the industry's standard bearer for quality and craftsmanship.
Features:
- Two-pass u-flow configuration utilizing high-flow tubes for up to 40% increase in internal flow rates.
- Custom compressed core width to maximize airflow and enhance heat exchange.
- Optimized custom 9 FPI (Fins Per Inch) 45 micron copper maximized conductivity.
- Yields up to 30% more heat exchange capacity than the Black Ice® GTX in ultra-stealth operation mode up to 2000rpm.
- Built-in 15mm deep plenum for equalized core air pressure distribution.
- M4 Threaded Screw Holes for easier mounting and greater adaptability.
- Standard G 1/4" female threaded fittings.
- Full high-temper brass structural construction for weight reduction and superior corrosion resistance.
- High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme III, Black Ice® GTX360 and most 3x120mm fan form factor radiators.
- Uses 100% Non-corrosive water-soluble fluxing process.
- Fully RoHS compliant.
- Full electrostatic polyurethane painting finish for uniform coating with high temperature curing for increased finish durability.
- Carbon Black Finish.
- Renowned Black Ice® quality.
- Patent Pending Design.
Was £78.98 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
EK Multioption Reservoir X2 250 Advanced [3831109840085] @ £34.99 inc VAT
The multioption X2 offers at least twice as much setup possibilities.
Manufactured of first class quality 60mm acrylic tube and POM Acetal, sealed with quality EPDM rubber washers. New version has the outer diameter of 60mm (compared to old version which had 50mm).
All new features give customer better mounting, easier filling and faster bleeding. Bottom part gives user 5 options for placing the G1/4 fittings/barbs as inlet or outlet. Top part gives additional 3 options for placing the G1/4 fittings/barbs as inlet or outlet. So the advanced version has total 8 options. Unused G1/4 ports are plugged with enclosed G1/4 Plugs. Additionally the reservoir comes with three internal 12mm ID and 16mm OD tubs in different lengths with thread on one end so it can be screwed into threaded ports inside the reservoir (2 × bottom, 1 × top). The most important property/advantage of the Advanced Multioption X2 reservoir is the exchangeable insert in the bottom part.The stock delivery comes with Insert #1 which is rotatable for additional options for routing the water flow. Advanced version also comes with an anticyclone which can be replaced with Insert #1. All inserts are fastened with stainless steel M3 screws.
New Multioption X2 Reservoirs comes with a pair of EK design reservoir holders with adjustable fastening force with enclosed Allen key.
Please check for Multioption X2 Reservoir accessories for different Inserts.
Technical data:
- Installation height: 250 mm
- Diameter: 60mm
- Capacity: 285 ml
- Weight (package only): 0,44 kg
Enclosed within delivery:
- EK-Multioption X2 Reservoir Advanced
- 3 × Internal 12mm ID 16mm OD tube with thread on one side
- Pair of EK reservoir holders with mounting screws
- 6 × G1/4 Plugs
- 1 × 6mm Allen key for plugs
- 1 × 2,5mm allen key for reservoir holders
- 1 × 2mm allen key for exchanging bottom inserts
Was £40.84 Inc. VAT
Only £34.99 inc VAT.
ORDER NOW
EK PSC Compression Fitting 7/16 [16/11mm] - G1/4 - Black @ £3.10 inc VAT
New EK Perfect Seal Compression Fitting (PCS Fitting) is a real high flow fitting. Made of brass with quality o-ring. Surface is coated with quality black finnish that is used for automotive industry.
A unique design with side imprinted EK logo will give your watercooling system a higher value.
Technical data:
- Thread: G1/4
- Outer diameter of fitting: 22-22,2mm
- Lenght: 27mm
- G1/4 thread lenght: 4,5mm
- Inlet hole ID: 11mm
For tubes:
Metric:
- ID 12mm; OD 16mm
- ID 11,1mm; OD 15,9mm
Inch:
- ID 15/32"; OD 5/8"
- ID 7/16", OD 5/8"
NOTE: Fittings may have minimal internal surface not coated with black color, due to technology used. This is not in any way effecting products use and has no effect on watercooling system and its components.
Made in Slovenia - EU, ROHS Compliant!
Was £3.50 Inc. VAT
Only £3.10 inc VAT.
ORDER NOW
Bitspower G1/4" Black Sparkle Compression Fitting For ID 1/4" OD 3/8" Tube @ £3.50 inc VAT
Features:
True Hi-Flow Design.
Hi-Quality Brass Material.
High Durability Nickel Finished In Black Sparkle Color.
Hiding O-Ring Design.
World First Compression Fitting Designed For Tygon 3603 ID 1/4" OD 3/8" Wall 1/16".
RoHS Compliant.
Thread : G1/4"
Thread Length : 5MM
Tubing Size : ID 1/4" OD 3/8"
Was £3.98 Inc. VAT
Only £3.50 inc VAT.
ORDER NOW
Enclosed:
- water block
- thermal pads
Was £69.98 Inc. VAT
ORDER NOW
Enclosed:
- water block
- thermal pads
Was £96.98 Inc. VAT
ORDER NOW
- G1/4" Thread
Was £39.98 Inc. VAT
ORDER NOW
Features:
Was £78.98 Inc. VAT
ORDER NOW
Technical data:
- Diameter: 60mm
- Capacity: 285 ml
- 6 × G1/4 Plugs
Was £40.84 Inc. VAT
ORDER NOW
Technical data:
- Thread: G1/4
- Lenght: 27mm
For tubes:
Metric:
- ID 12mm; OD 16mm
Inch:
- ID 7/16", OD 5/8"
Was £3.50 Inc. VAT
Only £3.10 inc VAT.
ORDER NOW
Features:
RoHS Compliant.
Thread : G1/4"
Thread Length : 5MM
Was £3.98 Inc. VAT
Only £3.50 inc VAT.
ORDER NOW
