But I am intrigued in the EGR as pat_1234 suggested. Can u offer a little more advice please, been trying to look around on the EGR but can't seem to find any decent place to locate its actual position in the engine??
http://www.google.co.uk/search?hl=e...leaning&aq=1v&aqi=g1g-v1&aql=&oq=vectra+b+egr
to
http://www.vauxhallownersnetwork.co.uk/showthread.php?14639-EGR-Valve-can-it-be-cleaned
gets;
u remove the plastic ecotec cover , two torx screws, egr is on right side of engine as u stand at front, cylindrical in shape with connector at top....has two et45 (i ithink that size) bolts that holds it on...easy peasy to change...
I'm rather suprised to see that this engine doesn't use a MAP/MAF sensor but is instead effectively Alpha-N??
		 ) but bledd. you make a good point. I am having the same problems as you describe minus the stalling part. I might also have a look at cleaning the idle control valve if I'm going to be cleaning the EGR valve with a carb cleaner anyways cheers buddy =) do you remember where about its located in the Vectra?
