This help?
Nah, its completely different now. As long as those science passes can get you onto Science A level you should be completely fine.
This help?
At A level hovever, every grade including an E gives you extra UCAS points, so it still helps.
At GCSE and Degrees yes.
At A Level you need 40% for an E, and at degree you need 40% for a third (if converting to grades like my uni liked to do, 40% = D-, anything less = F).
A 'D' grade (3rd equivalent) at uni is completely useless and wont get you anywhere either. In most subjects, particularly sciences, a 2:2 / 50% / C grade average at Uni is completely useless too.
If you get less than a C in any of your GCSEs, then you are better off simply never telling people that you did those subjects, or if all your grades are below a C, you should honestly tell people that you dropped out of school at 15 ... That will actually help you out a lot more then saying you did your GCSEs and got bad grades.
) - giving me 510 UCAS points. Self studying Physics + Maths at Higher this year and I could end up with 654 UCAS points.
Not all the time, many of the top institutions and employers won't count such grades towards a UCAS score.
Assuming that if you get E grades, you wouldnt be applying to the top unis, but to metropolitan ones, or higher education colleges instead.
So really, as long as you get onto 6th form or Uni, don't worry too much if you didn't get all As.
Well, I got an E at As level photography, and I'm at a top institution![]()
We still talking gcses here or a-levels.
If you got below c at gcse you're not getting into metropolitan either.
Incorrect.
 xAnd most top universities don't look at UCAS score at all - they ask for specific grades, often in certain subjects.
8A*'s and 2 A's. I know gcse's are perceived to be easy by many of you but I can only do what's put in front of me.
8A*'s and 2 A's. I know gcse's are perceived to be easy by many of you but I can only do what's put in front of me. The only subject that I can see as being dumbed down is gcse french. For the oral I knew what the questions would be apart from two of them. Easy enough memorise my sentences and predict the two questions and that's easy enough as it's based on one topic like holidays. For the the writing section, I knew what the question was before I went in, easy again, all I did was write out an essay at home and memorise it again. The only challenging parts were the reading and listening and these were the hardest as I had to actually think.
I agree entirely. French is too easy, even with the harder IGCSE boards. Then again Spanish is easier still... French is the only subject that my school has students do early as it's just way too easy so they want to get students doing the Short Course Pre-U in French.
Congrats on those grades, be proud of yourself. Almost any university will be interested with those as long as you're doing useful subjects for A-Level.
