Hi first time poster here so be gentle!
I'm looking at a CM690 II advanced, an asus sabretooth p67 board and using a corsair H100 and curious if the radiator and fan will clear this armoured motherboard using the top fan mounts.
I was under the impression that (after seeing one actually fitted) it was a tight fit and some boards/cpu locations might scupper fitting one.
Otherwise would a H80 do a good job at keeping the i5-2500K cool enough when it's overclocked to 4k or so?
Thanks in advance for any tips, guidance or outright help
