Counter Strike: Source night!
I can only play it in short bursts before my awfulness sucks the enjoyment out of it. Good laugh for an hour tonight tho :)
Im crap, dont mind me i'll just flash my light at you.
Yeah votemaps would be good and slightly longer time on the maps.
I swear the hitboxes never used to be this bad O.o
Try checking the settings I listed earlier, they MAY help (or tweak them for yourself, if you still can't hit anything it's most likely your aim :p).
I'll look at the votemap option at some point soon. :)
So this will be why OcUK group keeps sending me messages via steam you set of stalkers :p
Ill try get on at some point source name will be Sparx or |BMC|Sparx
Again, I'm not on tonight as I'm working, but I will be interested in how busy it gets. The time is changing from Saturday to 8pm start to try to appeal more to those that prefer to play later. See you then. :)
@ Malteaser, the settings work for me, some of the commands may be in error though in which case they do nothing. :)
And if your stuck at 60fps turn off Vsync if you want more.
Yeah, one just gave me an error. And did that, and went up to 100. Cheers.
