TODAY ONLY 27TH AUGUST 2011 - KINGSTON & MSI
11 Dec 2005
Cheshire
Today only we have 40 units of the fantastic MSI ATI Radeon 6950 twin FrozR III Power Edition 2048MB graphics card for only £204.98 inc VAT! featuring a substantial overclock and the ultra cool FrozR III cooler, the MSI Power Edition is the graphics card choice of champions.
We also have 100 units of Kingston HyperX Genesis Grey 8GB 1600MHz C9 memory for only £39.98 inc VAT. Upgrading your system to 8GB has never been cheaper! With a swift 1600MHz clock speed and a low CAS latency you can be sure of impressive performance.
MSI ATI Radeon HD 6950 OC Twin FrozR III Power Edition 2048MB GDDR5 PCI-Express Graphics Card with Dirt3 & Deus Ex PC Games @ £204.98 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Core Clock: 850MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5200MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required
- 450W minimum PSU recommended
- Warranty: 3 Years
- Supplied with Dirt3 Download Voucher (Subject availability)
- Deus Ex: Human Revolution FREE download code. Only on orders placed on 26/08/2011 onwards. Your code shall be emailed to you Wednesday 31st August onwards, please don't call or email us before this time.
Was £219.98 Inc. VAT
Only £204.98 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) @ £39.98 inc VAT
Kingston's KHX1600C9D3X2K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX1600C9D3X2K2/8GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-9-9-27 2N
Capacity: 8GB (4GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.50-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Was £59.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Ordered one of the 6950s as soon as they came up on the site. I was going to go elsewhere if it was £220 but £205 is too good to turn down especially as you are getting two free games, both of which I'm sure to get a lot of hours out of.
Nice one Ocuk.
I'd be tempted to say wait for the 7xxx 6xx cards to but then again for that price and with that cooler the 6950 is a bargian and will max pretty much any game.
That ram is a bargain!
That ram is ever so tempting... you could get 16 gb for £80 lol thats insane
I have one of those Twin Frozr 6950's already and have been debating CF with another one just a shame payday aint anytime soon for me =P
EDIT : Just realised the ram is limited to 1 set per customer.. still an awesome price for 8gb under £40!
hmm kingston for £40 or corsair vengeance lp for £47? the kingston is today only while the corsair isn't(tho the price may change by the time I come to order).
on the note of the corsair will the standard vengeance have issues with a arctic freezer 7 pro rev2?
btw I wouldn't be getting a motherboard and processor(i2500k) for abit so worth getting the ram now? just spent £1000 or so on a new monitor(u2711) and 2x sapphire 6950 toxic so going to hold off for a bit before upgrading the q6600.
I registered today simply to say I pulled the trigger on both the daily deals.
I was deciding between the MSI 6950 and the MSI 560GTX TI so I'm glad I found this offer and made my choice easy for me.
Considering that there is only £5 difference between the cards right now, you get a hell of a lot more going with the 6950. More performance, lower power draw, lower heat, lower noise and Deus Ex (worth £29.99 on steam) AND Dirt 3 AANNDD the chance that it might unlock to a 6970 for even more performance! No brainer as far as I'm concerned.
Also the ram, which I didn't really need, was so disgustingly cheap that I had to buy it.
Now all I need to do is find somewhere selling cheap i5 2500k and OCZ Vertex 3 and I'll be sorted :)
Also just realised :(
Was gonan order 3 lol nvm will wait
aye was gonna grab a few for my upgrade later this year, just not decided wether with be dual or tri channel yet, woulda covered all bases lol
I ordered the MSI ATi card, will see significant improvements over the stock ATI card that came with my HP tower. Just hope my 500W PSU will be enough
