- 26 Mar 2010
- London
The pc is Dell Dimension 8400.
Detailed PC specs in this link: http://support.dell.com/support/edocs/systems/dim8400/SM/specs.htm
The pc has a 350 watt psu, was looking for ati x1950xt, but noticed they recommended above 400 watt. My current but on its way out graphics card is Ati X850XT Platinum edition. The card causes discolouring streaks across the screen on the background of the screen, I have tested and it is not the screen but the card. I'm a little confused with the whole x-something slots. This pc has
PCI 2.3
PCI Express x1 and x16
Bus speed
PCI: 33 MHz
PCI Express:
x1 slot bidirectional speed — 500 MB/s
x16 slot bidirectional speed — 8 GB/s
Does the above mean it only has one slot at x16 and is compatible with graphics cards upto the interface of PCI 2.3? So there is a possibility 5 series cards will be compatible but most likely not due to a 350 watt psu.
PCI 2.3
Bus speed
PCI: 33 MHz
PCI Express:
