Can't access Bios?
5 Jul 2011
I'm using an ASRock Z68 Exterme4 Gen3 and I need to get into the Bios to check something, but whenever I start the computer up and mash all the necessary keys to do so - nothing happens. Windows just boots up and I'm left with this face :confused: followed by this one :mad:
Can anyone help?
Are F2 and Del the keys you're mashing?
I assume your keyboard is USB.
Try using a different keyboard if you have one.
You may have better luck with a PS/2 keyboard or if you have a PS/2 adapter for a USB keyboard.
Are Z68 different then?, normally you would just press and hold down the del key to access bios, press and hold del key down as you boot up, no?, well, that's what i do to access bios menu.
