About to buy some Memory - does it all look correct?
12 Sep 2003
Newcastle, UK
Hey,
It seems that the Kingston HyperX Genesis Grey memory deal is just too good to ignore! I've been planning to upgrade my rig around AMD's Bulldozer CPU which should hopefully be arriving at the end of September.
Will this memory be OK? I plan to use it in the Asus Sabertooth 990FX AMD3+ mobo next month. I can't see any issues, can you?
http://www.overclockers.co.uk/showproduct.php?prodid=MY-094-KS
£79.98 for 16GB of DDR3! Love it. :D
Thanks!
Wey! Memory arrived today, super quick, cheers ocUK!
Obligatory photo...
Two separate orders worked a treat! Happy Days. :)
