- 3 Jul 2005
You have a metal sphere full to the brim with water, You then heat the ball to boiling point. The water expands so what would happen? Will the ball explode? Will the world implode ?
[FnG]magnolia;19944306 said:OP, is there anything - and I mean almost literally anything - that you do understand, if at worst only in conceptual terms?
Things
[FnG]magnolia;19944329 said:You appear either more lenient of the OP's posting history than I or have a stronger desire to educate than I.
Either way, you're the better poster here![]()
It depends.
It depends.
