Should I swap my 13"MBA for an 11"?
Don
18 Oct 2002
Wargrave, UK
I bought the 13" MBA thinking that the extra screen resolution and size would be a benefit to me. Also, the extra 2 hours of battery life would be helpful.
Today, I was in the apple store playing with an 11" and thinking; this is awesome.
The battery life difference between the 2 is in practice only 30 mins from Anand's review. Also, I'm not really using the device for productivity like I thought I would. I have a 3 screen desktop or a 17" laptop for that.
I'm mainly using it for browsing, news reading, email, document writing, and note taking.
Did anyone else buy the 13 and then change to the 11?
Is the 768 vertical resolution really a big issue?
I suppose I could go and buy an 11 and then sell whichever model I don't want.
I have an iPad and I don't use it as I find it too restrictive.
My issue with the 13" MBA is that it's just a teeny bit too big to be ultra-portable.
With the rest of your kit the 11'' probably makes more sense. I have the 13'' and love it but it's my main computer. The 11" would be too small for me.
Anyone that says a netbook is an equivalent hasn't compared the 2.
The 11" air is fine- nothing bad about the resolution... And is definitely more portable than the 13".
Well the 11" is available for just £749 (£705 after cashback) at a well known household goods store if you're still planning to go for it. Not sure if I can name them on here as they could be seen as a competitor.
Just bought one myself.
If it's the place I think, that's the 2010 model they have for that price.
