- 7 Feb 2004
I've just put 12 dimmable megaman cfl's in an extension with a dimmer switch and they are spot on. Make sure you use a compatible dimmer that megaman recommends and you'll be fine, the dimmer I used was a bit of an industrial jobbie and wasn't cheap though.
You have to leave them on for a couple of minutes before dimming to allow them stabilize and they don't go as low as an incandescent maybe 40% to 100% brightness.
