- 29 Aug 2010
- Cornwall
Hi,
I suspect this has been asked before (possibly even by me) but a quick search didn't bring anything up.
I'm thinking of adding some quick disconnects into my loop when I redo it. Just wondering if this is a good idea? I'd probably look to put 2 or 3 in there (separate the pump & res, the radiators and the cpu/gpu blocks).
So do they cause a big problem with flow rates/restriction or are they ok in small numbers?
My loop will hopefully be:
MCP35X + XSPC dual bay res
HeatKiller 3.0 CU CPU block
XSPC Razor 480 GPU Full Cover block
EK Coolstream XT 120 Radiator
Black Ice SR-1 360 Radiator
I believe both the CPU and GPU block are more restrictive than some on the market so would adding 2 or 3 Quick Disconnects into the loop ruin the flow to the point where it's an issue?
Thanks.
Thanks.
