Does anyone here run a double DIN head unit? I'm looking at going this way in my long long long overdue proper ICE install in the E39 because I think we've finally reached a point where it can be done without looking totally horrendous (Though opinions on this side of things are not required thanks very much). It is roughly comparable in cost to the only other real alternative - the OEM Nav retrofit.
I think I've narrowed it down to two units and I'd be after any advice or opinions on either unit - has anyone got one or used one?
I'm looking for something that gives me full multimedia capability in the car - bluetooth telephone, iPod control, SD card reader, USB interface radio and Satellite Navigation all integrated.
The two units at the top of the shortlist are:
Pioneer AVIC F20BT
This unit seems to have the best and most modern looking interface of all. It's slick, seems nice to use, modern fonts, etc etc. It's also a Pioneer so its likely to be the better head unit from a sound quality perspective. It's also reasonably priced - you can pick it up for £800 as it was recently replaced by the F30BT which adds almost nothing worth having. The downside is the navigation side of things - I believe it uses iGo8 for navigation which is appparently pretty sub-par.
Sony XNV-L77BT
This unit doesnt quite have as slick an interface as the Pioneer. It's also a Sony, so whilst I've never been unhappy with any of the Sony ICE products I've had before, it's pretty much a fact that the Pioneer will have better sound quality. It's also more expensive than the Pioneer, coming in at £900. They do a 66BT but it has a smaller screen and a thicker bezel with more buttons on it which begins to look a bit crappy - the benefit of the 77BT and the Pioneer is that almost all of the unit is simply screen - which makes it look far less aftermarket than it otherwise would. The 77 is almost entirely unbranded whereas the 66BT is plastered with stupid XPLOD and DivX logos.
You might therefore think its a no-brainer and that the Pioneer wins hands down. But the Sony has an ace up its sleeve - the navigation side of things is basically the latest TomTom unit with IQ routes. Say what you like about navigation but I firmly beleive TomTom is the market leader. I love the interface, I love the routing, I just love the products full stop. I rate Tomtom higher than any navigation system I've ever used and as a result it's really making me lean towards the Sony - having a large, widescreen version of the current generation TomTom units - with full European mapping, Live services and all the other jazz you get with the top end £200+ TomToms, is just hugely appealing.
So, anyone got one?
Or am I overlooking another unit?
Pioneer AVIC F20BT
Sony XNV-L77BT
So, anyone got one?
