Yay for common sense[TW]Fox;19952201 said:I have decided that spending 1k fitting a 10 year old computer just because it looks a bit better than the bezel is just silly.
And increases the value of your car by about 20p. People saying OEM looks better. Of course it does. But does it perform better? I doubt it, my £30 nav would run rings around it.
At least with this option Fox can remove the unit when he sells the car and install or sell elsewhere.
[TW]Fox;19952258 said:It is also 10 years old, as I keep saying.
I had a sound system install custom done on a 750 a while back and apart from the extended door panels I could not tell it wasn't factory fitted kit.
The firm matched the BMW elephant skin effect perfectly. Maybe that would be the way to go?
[TW]Fox;19952274 said:The finish on the Janus design bezel exactly matches that of the oem radio.
[TW]Fox;19952327 said:The BMW Nav sucks.
And the bezel looks awful.
As you have to move the AC down, how easy is the fit to do yourself? Will you be doing it or will you pay someone else to?
I think it looks passable as it is, the perfect bezel isnt available but that doesnt look bad enough to warrant fitting 10 year old rubbish in comparison to an interchangable bang up to date bluetooth/tomtom system.
My point is, that brushed aluminium effect vinyl is available from 3M (DI-NOC stuff), and black dashboard vinyl is available. I'd go that route if I HAD to have a bezel.
