LOWEST UK PRICE - GIGABYTE Z68XP-UD3 £99.99 inc VAT
11 Dec 2005
Cheshire
Onboard mSATA, USB 3.0, SATA 6GB/s, SLI & Crossfire support all wrapped up in a Z68 chipset for less than £100?! Hell yeah!
Gigabyte Z68XP-UD3 Intel Z68 (Socket 1155) DDR3 Motherboard ** LOWEST UK PRICE ** @ £99.98 inc VAT
Based on the Intel® Z68 Express Chipset and supporting the new 2nd generation Intel® Core™ processors, the GA-Z68XP-UD3 motherboard delivers the very best that Intel® 6 series chipsets have to offer, including a significant performance boost with Intel® Smart Response Technology, the first ever mSATA drive connectors on a standard desktop PC motherboard, and GIGABYTE's proprietary Touch BIOS™ technology. The GIGABYTE Z68 series motherboards put users in the driver seat, allowing them to take total control over how their system operates and performs to best match their individual computing needs.
GIGABYTE Z68 motherboards are equipped with the much anticipated Intel® Smart Response Technology, allowing users to experience system performance similar to SSD-only systems. Intel® Smart Response technology works by using intelligent block-based caching of frequently used applications to improve system performance and responsiveness. In fact, GIGABYTE Z68 motherboards with Intel® Smart Response Technology are able to outperform hybrid drive systems by more than 2X (PC Mark Vantage HDD test) and HDD-only systems by as much as 4X (PC Mark Vantage HDD test) and deliver a 60% performance improvement over HDD-only systems in PC Mark Vantage Suite.
The GIGABYTE EZ Smart Response utility is a simple application that allows users to quickly and easily configure their system for Intel® Smart Response Technology. In the past, enabling Intel® Smart Response meant users needed to enter the BIOS in order to configure their system for RAID mode, which then required a complete reinstall of the operating system. Once that processes was complete, users then needed to install the Intel® Rapid Storage Utility as well as configure Intel's Smart Response Technology. GIGABYTE EZ Smart Response does all of this automatically, without users having to perform a complicated install process. This allows them to quickly and effortlessly enjoy a significant boost in system performance.
Only £99.98 inc VAT.
ORDER NOW
I currently have a h61 motherboard but this looks great for the price.
I only have a 4 pin CPU connector. Will i still be able to use with this motherboard?
Or do i need a new PSU?. I think i dont but would be great if someone can clarify that.
Also the Lucid Virtu, does it work with my 5770 or is it limited to Nvidia. (Probably a stupid question)
You can use a 4pin in the 8pin connection.
Its a way of using the built in graphics core of a sandybridge cpu to speed up certain tasks like video encoding, this is the Quicksync/Lucid Virtu
Its independent of ATI/Nvidia cards.
Ah,
Thanks Stulid as always :)
Now to really think if i need the benefits of a z68 over my H61.
You can overclock if you have a "K" cpu.
I tested the bigger/ badder brother of this recently, look at my last thread posted.
Ah thanks mate, still counting down the days till I can order it, but this mobo comes in exactly as the i5 went up in price...Which ruined any chance of buying the Asus mobo you suggested
