** NEW OcUK Watercooling Kits - NOW FEATURING XSPC EX RADIATORS **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Following on from the stellar response to our EK Watercooling Kit range, we have created a more specialist watercooling bundle range.
These bundles are specified to be 100% compatible and offer uncompromising performance.
Each of these bundles is picked by our Technical team and checked for quality before shipping.
All of our watercooled bundles now offer XSPC EX Radiators as standard which provide supreme cooling performance in a beautifully presented package.
The EX Radiator range also offers exceptional value for money to the end user giving massive savings on each of the high end kits
The V6 kit also features an EX radiator for the same price as the previously specified, cheaper radiator!
OcUK V6 Watercooling Kit 120 **2011 Compatible** @ £118.99 inc VAT
Until now, watercooling has been off-putting.
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
OcUK have stepped in and solved this problem. With each OcUK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike
Component List:
1X XSPC EX120 120mm Radiator
The latest radiator from XSPC, outstanding performance and superb quality
1X XSPC 200 Bay Reservoir & Pump - Clear
A clever space saving solution that allows you to see your coolant level from your drive bays
1X EK Supreme LTX CPU Waterblock - Nickel Acetal
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supreme' for a reason!
1X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fan
The most recognised performance fan for watercooling radiators.
1X Mayhems Ultra Pure H20 Watercooling Fluid
The purest water available - ensuring the best temperatures.
1X XSPC 7/16" ID [16/11mm] Clear
High quality watercooling tubing with a superb bend radius
6X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Silver Finish
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
IMPORTANT:
Kit is easy to install, use and maintain (thorough installation manual is available on our forums).
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Only £118.99 inc VAT.
ORDER NOW
OcUK V8 Watercooling Kit 240 **2011 Compatible** @ £189.98 inc VAT
Ideal for first time watercooling enthusiasts and seasoned veterans alike.
Component List:
1X XSPC EX240 120mm Radiator
Ultra high air flow and innovative built in shroud design offers uncompromised performance that is second to none.
1X EK DCP 4.0 Pump
A superb all round pump with a small footprint inside the case
1X EK Reservoir Combo DCP 4.0
A powerful aftermarket top and reservoir combo to ensure maximum performance from your Pump
1X EK Supreme HF CPU Waterblock - Copper Plexi
2X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans
The most recognised performance fans for watercooling radiators.
6X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Shining Silver Finish
IMPORTANT:
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
***NOTE***
Only £189.98 inc VAT.
ORDER NOW
OcUK V12 Watercooling Kit 360 **2011 Compatible** @ £266.98 inc VAT
Component List:
1X XSPC EX360 120mm Radiator - Black
Offering superb performance, build quality and value the XSPC EX range of radiators are the obvious choice for high end watercooled systems.
1X 12V Alphacool Laing D5 Vario Pump 655
The best watercooling Pump on the planet. Accept no substitutes.
1X EK-D5 X-Top V2 Acetal G1/4" - Pump Top
A powerful aftermarket top to ensure maximum performance from your D5 Pump
1X XSPC Single Bay Reservoir - Multi Fascia
A high flow reservoir for your D5 providing an easy filling and draining point in your loop.
3X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans
2X XSPC 7/16" ID [16/11mm] Clear
8X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Black Nickel Finish
IMPORTANT:
This kit can also be upgraded with an additional VGA waterblock!
You will need to buy two additional fittings alongside your graphics card block.
Please ask our friendly sales team for VGA block advice.
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Only £266.98 inc VAT.
ORDER NOW
I think it would be an excellent idea for you to offer these in the same way as configurable computers.
Even if it's only basic to begin with- e.g. option for compressions instead of barbs and different sizes/tubing.
I know this is off topic, and i am not going to try it, but... im curious
could you drink it?
So how do these match up against the EK kits?
they are better. better components in the loops on the V8 and V12 kits.
they are not designed to compete, they are designed to offer an even higher class of watercooling kit.
I would like to see all these three's compare with overclocking reviews please rjk
simply not possible at the moment mate - they are picked because they work.
if you were to give me a scenario [system spec/overclock/voltage] then i could give you a very well educated guess on temps.
any of these kits will hold a 5GHz 1155 overclock easily and outperform any aircooler or closed liquid cooler on our website.
z68x ud4 b3 i7 2600K @ 5.0GHz bios setting:
LLC level 4 @ 1.47v
Ram @ 1.62v @ 1600MHz @ 9-9-9-24-1T
rest on auto
(these are stable after prime95 24 hours) temp max is 78C on silver arrow
i would suggest the 240 or the 360 kits then
the V8 240 kit would expect temperatures in that scenario of around
65-75'C [depending on ambient and fan speeds]
the V12 360 kit would expect temperatures in that scenario of around
60-70'C [depending on ambient and fan speeds] but it does offer the opportunity to add a gpu and that would present a very small hit on cpu temps [say 5'c as a ballpark figure.
that is a lot of vcore to be using
and your ram only needs to be at 1.5v ;)
I have now set ram at 1.5v and I will try LLC 6 @ 1.42v overnight
Thanks for this advice rjk :)
Since seeing some nice watercooled rigs at the B.O and Burger fest that was I43, i'm interested in trying my own custom loops. Not sure whether to just go for the single 120mm rad or upgrade my case and go for a 240
Just had a ppi claim come back good mate so money isnt as much as an issue as it would be normally. Budget is around 500 for pc upgrade, im just worried about
1 leaks if I left the system on and went away from the rig for a few hours, and 2 what sort of maintenance I would have to do on it and how often
maintenance is a none issue really.
check the watercooling guide linked in my signature and go to the maintenance section.
why not consider one of the watercooled cases?
you can add me to MSN or skype if you want any more details about it :)
rjk I might going to order this case for next week possible this high end case here: OcUK V12 ULTIMATE Watercooled Case - Cooler Master for my Sandybridge i7 2600K @ 5GHz as I do believe this will be the best choice for my Sandybridge to be first time ever by a proper custom water cooling :) and can I choose the colour of the fluid to have blue instead ?
you can
you would need to speak to sales to ask them to change the clear fluid to the X1 blue fluid.
they can do this no problem.
the ultimate case is more than enough for your 2600k at 5ghz
