might be, depends what else is in the system tbh![]()
not with all that, sell the 650 and get a 750 or 800 to be safe![]()
650W is enough but not all 650W PSU's are the same.
What is the make and model of the PSU?
The Asus GeForce GTX 580 Matrix Platinum requires two 8 pin PCI-E power connectors. Unless your PSU has these you're going to have to use various adapters to make the necessary connections.
Thermaltake Toughpower Grand
Is that the TPG-650M with 4 red and 4 black connectors for modular cables?
If that's the one then according to the specification the PSU has two 8 pin and two 6 pin PCI-E power connectors and a 52A (624W) 12V power rail.
Two 8 pin connectors and a good 12V supply are what you need so it looks like you're good to go.
Yeah thats the one! So its good?
It's good.
The downside is that the graphics card is 3 slots wide so with it fitted the only slot left free on the motherboard will be the x4 PCI-E slot at the bottom.
The second x16 PCI-E slot will be blocked.
