Hey there all
N00b here, so appreciate all pointers. Hoping you ninjas of overclocking might help.
Basically I work for a financial services company, and we have some pretty important business applications that make us cash that are quite simply, limited by CPU speed. We presently have these deployed on a lot of Xeon servers running at 3.46Ghz, however we're very keen on looking at implementing them on overclocked Sandy Bridge platforms in a data centre environment. Probably looking to deploy about 50 or so of them.
A brief outline is that they run Linux so no video or GPU processing is important, along with us looking to try and achieve a stable overclock as high as possible. This last point is the whole point - basically, raw clock speed (and stability) is what's most important to us, and price isn't an issue, so what I'm hoping you might help with is combinations of hardware you've used that has given you a consistent and stable OC in the 5Ghz range. Thus far I'm thinking something along the lines of: -
Intel Core i7-2600k Sandy Bridge processor
Asus Maximum IV Extreme Intel P67 motherboard
Corsair Dominator 4GB (2x2GB) PC3-16000 (2000MHz) ***OR*** G.Skill RipJawsX 4GB DDR3 PC3-17000C9 2133MHz Dual Channel Kit
In this case I'm thinking cooling is going to be totally imperative, and haven't got much of an idea on this front, however have been thinking that the Corsair H70 is potentially something that might be of use? Unfortunately the data centres we're looking at won't let us put a full hydro setup in there, so something which is a self-contained hydro solution might be a good approach, then again space considerations to be able to put it on the mobo (if I go with the Dominator GT RAM with the fans on top) might come into play. Also, data centres are controlled environments - is an air solution possibly better than a hydro CPU cooler?
Anyway, I'm getting further and further into it. Again, appreciate all comments - thanks in advance for your help!
Cheers,
Damo
