Should be grand if memory is the same amount, and you have a good quality psu.
Got a Coolmaster Real Power M1000, sure that should, be fine?
Yep.
kk cheers for replies will drop a line here when its installed don't think card will arrive till Wednesday public holidays
...anything I need to watch out for?
The shocking dissapointment at the lack of extra performance?![]()
You need to overclock your CPU more...a 920 @ 3.6Ghz will create a bottleneck for 570 SLI
Get it up to 4.0Ghz
Cheers will up the speed a bit![]()
