75% off everything Borderlands on Steam
I have 2 keys showing and have unlocked those. Should I have more?
No there's a key for Zombie and another for Mad Moxxi. It seems there are lots on the Steam forums with the same issue. I did have two keys last night but tonight I only have one. :D I've not activated them yet so until they sort it I wouldn't be able to play Moxxi.
those with key problems do this
open steam folder
find your borderlands folder
look for binaries folder
go into the dlc set up one
enter key on steam in dlc checker
now go in game and you should be fine
try to go to jacobs creek if you can now play it it done
you can do this without entering game on desktop then when you fo back in it should be sorted :cool:
done it with loads of people today and been playing zombies on it all night
Weirdly the key shows up in the registry...
Open a copy of the registry editor. Find the key:
HKEY_CURRENT_USER\Software\Valve\TestApp40940
Only two of the DLC's have keys.
If you go into the borderlands properties page in steam and click the DLC tab it'll show all four.
weird male but i know what u mean yesterday loads on ts and i was saying how many keys you got some said 1 some said 3 :confused:
thing was all did the method i described with either the one key or two of the 3 (top two keys in steam ) and then i said try top go to jacobs creek .
only one out of the lot couldnt.
seen the steam thread though that some cant :( gutted if your one of these.
Well I got hold of the key - both the DLC keys are showing in the registry but only one in Steam. So I'm good to go. :D
Well had the server up since 7.05 and nobody joined...
Game is making me feel very nausated still, so i'm gonna stop playing :(
Aw damit, i loaded up at about 7:30 and found your friend req, and your game seemed to be running and joinable. Went to join and made a cupa tea but timed out of somthing, assumed you had a full sever so went to mess about in BC2 :(
